Using Building Paper Correctly When Applying Stucco
Using building paper correctly when applying stucco can be a tricky job, especially if you have never done it before. It is important though that you make sure that you are installing the building paper properly so that moisture doesn't get in and cause any damage. Here are a few things that you will want to keep in mind while you work to ensure that the process goes smoothly.
Apply Like Shingles
Apply the building paper like you would apply shingles on your roof. This may seem silly, but having a layer put down, and then overlapping, allows you to cover the entire area. This keeps the moisture out and gives you a blanket that you can then apply the stucco on.
Use Nails
Using nails is the best way to apply the building paper. Many people think that the best way to apply it is with glue or adhesive. This often times will come off and is not secure enough. If you use a hammer and nails or a drill to install the paper, it is more likely to stay put with no problems.
Apply in Good Weather
Be sure that when you are applying the paper, the weather is clear. This will ensure that it stays on well.
