Using Exterior Brick Siding on Your Home Using Exterior Brick Siding on Your Home
Exterior brick siding is one of the most common types of siding in the world today. When you use this type of material, you are going to get several benefits from it. At the same time, there are a few potential drawbacks of which you will want to be aware. Here are a few things to consider about using exterior brick siding on your home.
Initial Cost
One thing that you should consider is the initial cost of having the brick siding installed. In most cases, installing brick is going to be a fairly expensive project. You are going to have to invest thousands of dollars in order to get this job completed. Most people cannot do this job on their own and have to hire it out to a company that specializes in this type of work. When you compare it to some of the other types of siding, this is going to be more expensive in the majority of cases.
Ongoing Costs
Even though the initial cost of brick is going to be expensive, the ongoing costs are going to be very reasonable. You are not going to have to replace bricks very often and they are very easy to maintain once you get them installed. With other types of siding, you may have to replace pieces periodically after a storm or if something hits the side of your house. Brick is not going to require much of an investment once you have had it installed.
Look
The look that brick provides is very sought after. Most high-end homes utilize brick siding. It comes in a variety of different styles and colors which allows you to customize the job to your specifications. A talented installer can do a number of different patterns and designs within the brick wall.
Durability
One of the best things about brick siding is that it is extremely durable. You are not going to have to replace the siding for a number of years. In many cases, brick siding can last anywhere from 50 to 100 years. Most people do not live in one house for that long, so you will most likely never have to replace it. Brick siding is also very difficult to damage. It can stand up to a great deal of wear and tear and it is never going to show any signs of damage. For example, if something is thrown into the side of your house, it is not going to break the wall or dent. With vinyl or stucco, the wall might be severely damaged.
Fire Resistant
Another advantage of using brick siding is that it is fire resistant. It is not going to catch on fire and it will not allow fire to go through it. Therefore, if there is a fire outside of the house, it will not be able to catch your house on fire where the brick is located. This can provide you with extra peace of mind and can save you money.
