Vinyl Siding Ratings Explained Vinyl Siding Ratings Explained
If you are considering adding some sidings to your home, then you may be interested in learning about vinyl siding ratings. A lot of the time, it can be difficult to know what the right type of vinyl for your needs is, and this can mean that you buy the wrong variety, or end up with siding that falls apart after a few months. The vinyl siding ratings system divides the sidings up into particular areas, such as size, profile, color, and fire retardant abilities. All of these mean that by using the vinyl siding ratings system, you will be able to choose the right kind of siding for your home and not be disappointed. By using these ratings, you can make finding vinyl siding a lot easier.
Looking at Thickness
The first area that you should look at on your vinyl sidings is the thickness. The bigger the thickness rating, the more durable your sidings are likely to be. However, the vinyl is also priced according to thickness, so you can use the ratings as a happy medium between the two. Choosing a .040 or .045 siding will allow you to combine a suitable thickness with a cheaper price. However, if you are in an area which suffers a lot of high winds and rain, then you might consider going for a .055, which will be thick enough to endure even the most extreme weather.
Looking at Profile
Once you know what kind of thickness you need for your vinyl, you should try and look at the profile of the siding. This profile is designed to match wood siding closely so that you get a good resemblance for your money. The styles are given ratings so that you understand which is which. A D4 has 4 inch lapping boards, and the D5 has 5 inch laps. The siding known as Dutch lap is known as D5DL, and you can also get three boards of siding, known as a T3.
Looking at Fire Retarding Vinyl
As you are fitting your vinyl to the side of your house, you will naturally be interested in the kind of flame resistance which your siding can offer. Vinyl is usually given two kinds of ratings. ASTM D3679, which is the lowest rating possible while still meeting requirements, and the ASTM E119, which really means that it is the same as other types of vinyl materials, such as wood or metal siding.
Looking at Color
You can also examine the color of your vinyl. The vinyl siding ratings for color are not always consistent and may vary between manufacturers, but if you look at the ratings panel on your siding package and notice any kind of additional numbers of letters, this will be a color rating. You may find that the coloring of your vinyl is much lighter than you would expect, as darker vinyls will fade quickly.
