What are some common causes for a bathtub drain stopper to get stuck? What are some common causes for a bathtub drain stopper to get stuck?
The bathtub drain stopper is used to prevent water from flowing down the drain. However, sometimes they can get stuck and you are left with a full bathtub. The most common cause for a bathtub drain stopper to get stuck is a blockage caused by hair, the plug can get tangled in stands of hair that find themselves in the drain. It is important to clean out the plughole regularly, especially if you have long hair, or you are losing your hair. A quick tip: a coat hanger is perfect for pulling up those loose hairs.
