What Are Some Signs That a Brake Drum Shoe Needs Replacement? What Are Some Signs That a Brake Drum Shoe Needs Replacement?
When damaged or worn out, a brake drum shoe needs to be immediately replaced, as it interferes with the efficient functioning of the car brakes. The following are telltale signs that signify replacement.
Screeching or Squealing
When applying brakes, if the car is giving out sharp screeching sounds or if a squeal like noise is heard, you have to change the shoe brakes. When you apply the brakes, listen to any sounds being emitted from the rotors of the vehicle. If you hear a sound like that of a mixer in grind mode, replace the brake drum shoe.
Low Fluid Levels
If the fluid of the master cylinder of the rear brake is at a low level, that signifies a damaged brake shoe. If you have traveled with the vehicle for a long distance over a fairly long time on roads that are potholed and rough, the shoe will get worn. Inspect it and replace the brake shoe if necessary.
