What Are UPVC Door Locks? What Are UPVC Door Locks?
UPVC door locks are made of UPVC material, which is an abbreviation of unplasticized polyvinyl chloride, and are used in a wide range of construction and building fittings along with many other uses.  It is also sometimes referred to as rigid plastic. These UPVC fittings come in a wide range of colors as well as finishes. They are used in plumbing, window frames, weather boards and door locks. The use of UPVC door locks is quickly gaining popularity due to several factors that include:
Cost
UPVC door locks are cheaper compared to locks of a similar quality made using other materials.
Safety
UPVC door locks are actually in competition with locks made from materials such as aluminum and have been proven to be much stronger than wood. These locks, if installed along with a UPVC frame, will secure your premises very well.
Maintenance
There is minimal maintenance required with UPVC door locks because they neither rust like metal nor rot like wood does. They also happen to be very easy to clean; a wet piece of cloth is all that is needed.
Composition
Most UPVC locks comprise of four basic parts, which are the handles, the barrel, the receivers and the locking mechanism. The UPVC multi-point door locks will secure your doorway at several locking points, thus holding it firmly all around. These locks are suitable for all doors and entrances as well as windows.
There are some people who have complained about a UPVC door lock being easy to pry open. However, this only occurs where the fitting is not done poorly. A well fitted UPVC lock will hold as well as any other door lock can. If you have fitted these locks, it would be prudent to make sure that they are properly fitted.
Easy Installation
Another great aspect of UPVC door locks is that they are very easy to fit or replace. In case one is broken, you need only get a similar lock in size and design, so for a multi-point lock, make sure to get a multi-point lock of similar size. You will then remove it and fit a new lock by using the screws that hold the lock in place just as you would any other lock.
There are several UPVC door lock brands in the market, and you can ask your local locksmith or hardware dealer for advice on the best quality locks available in your area.
Though a good alternative to conventional locks, the use of UPVC door locks has been criticized as being damaging to the environment during their production as well as when they are not properly disposed of. However, these concerns are constantly being addressed through improved production technologies as well as the recycling of broken or unused locks.
It is also very important to note that plastics are flammable and should not be exposed to flames and excessive heat. Though there are no records of fires due to UPVC locks, prevention is best.
