What Does a Go Kart Torque Converter Do?
What does a Go Kart torque converter exactly do? A torque converter is also found in regular vehicles; the following are the things a torque converter can do.
Functions of a Torque Converter
  • It will use or convert the energy coming from the engine and use it as the Go Kart runs. This means that it will allot some energy for other functions in the Go Kart.
  • This will automate the functioning of the Go Kart in terms of its gear in connection with the speed. For example, if the kart is running at a lower speed, it will also change to low gear. At this state, the Go Kart will be able to run faster than usual and even climb higher.
  • In the Go Kart, the torque converter also keep the driver safe because of its option to change over to manual control. The reason for this is that even if it automatically shifts gear, it will still maintain proper manual control to keep them safe.
These are only some of the features that may answer to the question what does a Go Kart torque converter do. Because of its many advantages, many Go Kart owners invest to have the best torque converter that they can get in the market.
