What Equipment You Need for an Aquaponics System
An aquaponics system is a symbiotic marriage of plants and aquatic animals cultivated in a recirculating environment. There are various types of aquaponic systems used for growing vegetables or plants. Knowing how big you want your aquaponic system to be before you purchase it will allow you to set a budget. Read on to learn a little about the basic equipment needed for aquaponics systems.
Fish Tanks and Stand Pipes and Tanks Stands
Aquaponics is a blend of aquatic animals living in an environment where they provide the nutrients for the plants or vegetables growing in the same water in which they live. To begin creating your aquaponics system, you will need to decide which fish and other fauna you would like to house and how many you need. They will need a tank to live in and the tank requires stand pipes. You will also need to position your tank on a steady area or stand.
Clarifiers
You will need clarifiers for your aquaponics system. These are highly recommended as the best way to remove solids from the culture water. They also assist with the de-nitrification process and remove ammonia and nitrates. They are responsible for removing almost all of the water in the recirculation system and they can be used many times over with just marginal replacement needed from flushing the system to remove any solids that get trapped.
Bio-filters
Keeping the water clean and balanced in your aquaponics system is essential to keep it running efficiently. Bio-filters are a great way of controlling water pollution by biologically degrading and processing pollutants. There are horizontal bio-filters and upright bio-filter tanks available as well as a range of other types.
Oxygen Systems
Because you are keeping fish in your aquaponics systems, you will need an excellent oxygen distribution system. This is one of the must-have features as this is highly intrinsic to the health and growth of the fish. It will distribute oxygen to an optimum level suitable for the fish you have in your system.
Pumps
You will need a pump (or multiple pumps, depending on your system set-up) and the pumps serve a very important purpose. They will pump the water around the system, allowing it to be cleaned as it goes through the bio-filter and will return the fresher, cleaner water to the tank for best results.
Sundries
There are other smaller items needed to get your new aquaponics system up, running and performing as you need it to. Pipes and tubes and other accessories will be required and the best place to find them is in a kit found at a specialist store on website. Learn as much as you can about how aquaponics work before you commit to buying a complete system.
Plants and Fish
You will want your aquaponics system to function well for both your plants and the aquatic creatures you want to live and grow in your system. Choose the right fish that support the plant environment for the best results.
