What is a Pier Foundation?
A pier foundation is built several feet above the ground. It is supported by pillars and post. This type of foundation is commonly found in buildings around coastal areas. One of its main features is that it lifts the house above the ground. It makes it a popular design around coastal regions as it prevents damage to the structure in the event of flooding.
Less Labor and Materials
There are benefits associated with building houses using pier foundations. It requires less labor due to the quantity and materials need for installation. This helps to cut on costs. The design of the foundation protects the house from potential damages in the event of flooding.
Allows Wide Range of Designs
This design makes it possible to use a wide range of materials. It is possible to select such items based on cost in case it is necessary to stick within a specified budget. There are different materials that can be used depending on their aesthetic value and functionality.
Consider Extra Costs
There is need to factor costs associated with insulating the house once the job is done. It is important to insulate and seal the floor. This can be done on the walls and roof as well. This can come in as an extra cost and it is important for to factor it in the budget. Insulating the floor keeps the house warm while sealing safeguards building material from attacks from insect or pests.
