What Is a P-Trap?
A drainage system.
A p-trap is an essential part of virtually any drainage system. Here is what you should know about p-traps.
Appearance
A typical p-trap is made up of a curved trap piece, a drain elbow, and a tailpiece. In addition, p-traps feature a water seal that allows wastewater to flow safely into sewage systems while preventing dangerous fumes and gases from entering your home through sewer lines. P-traps come in both plastic and metal varieties. Surprisingly, metal p-traps have a tendency to corrode at a much faster rate than their plastic counterparts. Also, p-traps vary in size from 1.25 inches and 1.5 inches in diameter.
Function
The basic function of a p-trap is to ensure that wastewater is properly drained and freshwater is able to take its place. Each time one of your home's drains is used, the wastewater is flushed through the drain's p-trap and subsequently replaced by new water without any harmful gases or fumes finding their way into your drain. P-traps are used for tubs, washing machines, sinks, and most other common household plumbing fixtures. P-traps will inevitably wear down and incur clogs over time, but fortunately, they are relatively easy to replace.
