What is Cement Bonded Particleboard?
1-40 hours
Beginner
- 0-1000
You can use a cement-bonded particleboard as a lower-cost alternative to hardwoods such as solid oak or maple.
Understanding Cement-bonded Particleboard
Cement-bonded particleboard is made-up of Portland cement and wood fibers. It is retailed in sheets of varying thicknesses. Different kinds of softwoods like beech, pine and spruce for making particleboards. A particleboard is cut with a disc-chipper. After cutting the wood into particles, it is allowed to dry. Resin is applied to glue the particles together and render the board, more stability. These glued particles are then shaped into sheets.
Particleboard Types
Cement-bonded particleboard is available with square edges or a tongue-and-groove combination. It is often finished with a factory-applied sealer for additional protection against moisture. Cement-bonded particleboard is available as graded density particleboard or the conventional, three-layer particleboard.
Particleboard Uses
Cement-bonded particleboard is used for making bookcases, cabinet-ends and countertops, making it a useful interior-remodeling choice. The surface of particleboard is often laminated to make it look like hardwood.
Cement-bonded Particleboard Advantages
Cement-bonded particleboard is easy-to-install. It handles like plywood but maintains the characteristics of poured concrete. It is also resistant to mold/fungus, moisture, abuse, freezing/thawing, fire and termites/vermin. Leading green-building material directories recognize cement-bonded particleboard as an environment-friendly product.
