What is Polyurethane Caulk? What is Polyurethane Caulk?
If you've been toying with the idea of using polyurethane caulk in an upcoming construction project, you're probably eager to learn more about this unique type of sealant. So if polyurethane caulk has piqued your interest, read on to educate yourself on the basics.
Appearance
Polyurethane caulk has a very sticky consistency and aesthetically bears a strong resemblance to putty. Although the application process can be a bit tricky, this type of caulk can be stretched across very long distances. Additionally, it is able to adhere to virtually any surface.
Uses
Because of its flexibility and durability, polyurethane caulk is widely used in the construction of buildings. What's more, it makes an excellent coating for wood surfaces. Its resistance to scuffing and abrasion have helped polyurethane caulk become a popular coating for wooden floors.
Benefits
While it comes with a steeper price tag than other types of caulk, you will find that polyurethane caulk is well worth the additional cost. In addition to being extremely flexible, this type of caulk is very resilient and is often able to last a lifetime. Also, once it dries, the caulk produces an easily paintable surface. Just make sure to have the proper tools on hand when applying your polyurethane caulk.
