What is the Best Brake Fluid for Your Car?
Most people find it very difficult getting the best brake fluid for their cars. Brake fluid is what transmits the hydraulic pressure in the hydraulic lines into the mechanical brakes in your car. Your safety in a car depends partly on the brakes. Therefore you should always use the best brake fluid.
DOT Rating
All brake fluids on the market are rated by the Department of Transportation (DOT). The minimum is DOT 3. There is DOT 4 and DOT 5. However, there is not much difference between DOT 4 and DOT 5. Therefore DOT 4 is the best. The rating is done according to the boiling point of the brake fluid.
Consider How You Stop Your Car
If you do normal driving without sudden and hard braking, then DOT 4-rated brake fluids are the best for your car. But, if you find yourself doing sudden and hard stops, then you should consider brake fluids with higher boiling points.
Change Your Brake Fluid Regularly
The best brake fluid is not what is in the store; it is the one in your car. Brake fluids wear with time. Therefore, the best brake fluid is that which is new and regularly changed. Plan to change it at least every 2 years.
