Advice on Choosing the Best Flooring for Basement Laundry Rooms
laundry room
When you are deciding on the best type of flooring for the basement, keep in mind the inherent challenges that the location of flooring materials brings. Basements are usually below ground level, often near natural water levels outside. Moisture tends to find its way into your basement area. The following 3 basement flooring options are worth considering.
Paint or Stain Basement Floor
Both options are fast and efficient ways to deal with basement floors and potential moisture damage.
Install Ceramic Tiles
When properly installed with vapor barriers, tiling is a great choice.
Clear Seal
If you can live with concrete color, simply apply a coat or 2 of clear sealer. Clean and effective.
