What Is the Best Time of Year to Repair an Asphalt Crack?
If you need to repair an asphalt crack in your driveway, you may want to take a few minutes to plan the best time of year to do it. Here are a few things that you will want to consider.
Temperature
Temperature is a huge factor when it comes to repairing the cracks in your asphalt. You will want to check and make sure that you are finding a time during the year where the temperature is above 50 degrees Fahrenheit at least and below about 75 degrees. While you do not want the temperature to be too cold where it cracks and freezes, you also do not want it to be so warm that it will not set.
Weather
The weather is also a big factor when it comes to finding the right time to repair asphalt cracks. You will want to be sure that the day you are filling in the cracks as well as the next 2 to 3 days does not call for rain or snow. The best time for most climates to repair the asphalt cracks is typically between May and October.
Both of these factors will help you to decide the best time to repair the crack in your asphalt.
