What is the best way to apply a bar top epoxy?
Using a bar top epoxy coating to protect your bar top and give it an attractive glass-like appearance can be a simple task. There are two critical steps to doing it correctly: 1) Prepare your surface and 2) Mix the epoxy. Applying it is important but not as critical.
Preparing Your Surface
Be sure your surface is level, smooth, and clean before pouring the epoxy onto it.
Mixing The Epoxy
When mixing, add resin to your hardener -- not hardener to resin. Mix slowly by hand. For one gallon of epoxy, mix constantly for at least five minutes.
