What is the best way to apply rust-proof garage floor paint?
You can apply rust-proof garage floor paint in minimal time and with minimal tools, problems and mistakes. Follow the simple steps below to effectively and correctly apply paint on your own.
Step 1 - Clean Your Floor
Remove visible debris, and use a floor cleaner and brush to remove grease, oil and stains.
Step 2 - Caulk Cracks
Use a caulking gun to fill any small holes, and then smooth the caulk to level it. Allow it to completely dry before you move on.
Step 3 - Mix Paint
Add the epoxy to your paint, and stir it to get a solid color. Mix in non-skid granules at this time if you like.
Step 4 - Cut in Floor Edges
Use a paint brush to apply paint to floor edges near walls.
Step 5 - Apply Paint
Use a roller to apply paint to your floor surface.
