What is the best way to clean my drain tile? What is the best way to clean my drain tile?
Since drain tile tends to be softer than normal, it isn’t a good idea to use a heavy application of a scouring detergent because this will cause shiny tile to become instantly dull. For best results, create your own solution of vinegar and water. Wear a good pair of rubber gloves as you work, and apply with a soft cleaning rag. When finished washing, rinse thoroughly with clean water. You might also try a very gentle mix of a good mild kitchen detergent, or if you have a water jet hose attachment, you can use it to effectively clean your tiles.
