Applying Concrete Filler Is a Fast and Easy Way to Fill the Cracks in Your Basement Floor Applying Concrete Filler Is a Fast and Easy Way to Fill the Cracks in Your Basement Floor
If your basement floor has lots of cracks, you should consider applying a concrete floor filler. It is available at most home improvement stores. It fills the gaps in concrete relatively easily. It is similar to concrete, but it is not actually concrete. Concrete filler will not crack again, and it will adhere to the surface of the existing concrete. You can apply it with a trowel, or if the crack is very small, you may be able to simply squeeze it into the crack with a caulk gun.
