What Is the Best Way to Glue Veneer to Plywood?
When you need to glue veneer to plywood, the best type of adhesive to use is rubber cement or contact cement.
What Is It?
Rubber cement or contact cement is a substance that can effectively hold the veneer to the plywood without any issues.
Application
To apply, spread the adhesive onto the veneer and the plywood, and then press the two surfaces together. At that point, use a heavy roller to roll over the surface so that the two pieces of material are pressed tightly together. You need to remove any gaps between the two surfaces so that they will stick together well.
