What is the best way to remove wallpaper glue? What is the best way to remove wallpaper glue?
To remove wallpaper glue spots that still manage to cling to the wall despite sanding off the wallpaper, use about a tablespoon of baking soda to a gallon of water, and wet the area with a sprayer. Let the solution stand for about five minutes, and then, using the rough side of a sponge/rough scrub pad, scrub the glue off. For more stubborn spots, apply the same solution, but instead use a small scraper to remove the glue. It should lift right off.
