What Roofing Insulation Type You Will Need What Roofing Insulation Type You Will Need
With no shortage of roofing insulation types you will want to make sure you choose the right one for your home. Each types of insulation has it own properties as well as price points. It's worth it to do a little research to get optimal energy savings at the best price.
Fiberglass Insulation
Fiberglass insulation is one of the most common types of insulation. This could be because it's been around for a very long time. Fiberglass insulation works fairly well and is normally supplied on a roll where it can be cut to size and installed as a mat. Some people may find the fibers from fiberglass are irritating.
Rigid Foam Insulation
Rigid foam insulation is often easier to work with because it is a sheet. Although the sheets will still need to be cut to size they are much easier to handle. Rigid foam can be stapled or nailed into place.
Loose Fill Insulation
Loose fill insulation is fairly new when compared to the likes of fiberglass and rigid foam. This is a fairly good insulator which is very easy to install. The insulation material is typically reclaimed paper which is shredded and blown into the spaces that you want to insulate. The advantage loose fill insulation has is that it will fill any void regardless of the shape.
