What spray foam insulation kits work best for moderate climates? What spray foam insulation kits work best for moderate climates?
If you live in a moderate to warm climate then out of the many spray foam insulation kits available in the market, your kit needs to be the one that regulates the temperature. A spray foam insulation kit of 1.36kg (3 lb.) would be ideal for the job because it is resistant to heat flow, and therefore able to keep the temperature of the insulated room to within 10 degrees of the rest of the house. This type of spray foam is generally used in attics and lofts due to its high density level, compared to other cheaper foams including the 0.9 kg (2 lb.) foam, which is used in moist climates, and the 0.23 kg (0.5 lb.) foam, which is used for cavity wall insulation.
