What spray foam insulation kits work best for very cold climates?
When temperatures decrease, everyone thinks about insulating their home, however, spray foam insulation kits do not work well in cold climates because the foam peels away from the surface. With a few modifications you can use any insulation kit in cold weather: try heating the area you want to insulate before applying the spray foam, as this will prevent the foam from peeling. Techniques for heating the area include using a bullet heater or space heaters. It is equally important to keep the kits warm. In order to do this, store them indoors, and shake regularly to increase their temperature to a point that they are suitable for use.
