What to Do When Oil Furnaces Start Smoking
Oil furnaces are much safer than gas furnaces, especially when it comes to leaks. However, you will find that there are still a few things that you will have to worry about when it comes to getting your oil furnace as safe as can be. If your oil furnace starts to smoke, for instance, you will need to know the following steps to take to ensure that you and your family are kept out of harm’s way.
Shut Off Furnace
Whenever you have your furnace on and you happen to see smoke you will first need to turn it off. It is important that you do this as soon as you notice the smoke. Whatever the problem may be you will find that you will not be able to fix it until the furnace has been shut off. From there, it is also a good idea for you to shut off the switch at the furnace. Give your furnace time to cool off before you attempt to do anything else to it.
Routine Filter and Nozzle Change
Whenever it is time for you to start using your furnace again, it is a good idea for you to make sure that it has a good nozzle and filter to work with. You may need to change these out if you cannot remember the last time that it had been done. If the nozzle and the filter are not up to par then you will find that they could cause overheating which could cause smoke. Even if this is not the problem it is still a good idea to get the job done to prevent any future problems from happening.
Check Chimney
Check out your chimney. You may find that there could be a blockage. It is common for birds to set up their nests in chimneys. This is because they are safe and confined. The birds will come back year after year so it is a good idea for you to make sure if this is the case to find some protection for your chimney. This is for both your safety as well as the birds.
Flue Connector
You may also want to check out your flue connector. Loosen it up and take a look inside. Look to see if it is excessively dirty. Of course, there is going to be some soot and ash in there, but make sure that there is no build up. Layers of soot and dirt could cause a lot of problems with your oil furnace.
Call Professional
When all else fails it is always a good idea to call a professional. You can do these things yourself, but if you do not feel comfortable or do not trust your own judgment then it is always a good idea to get a professional’s help. They will be able to provide you with a detailed description of what was wrong and be able to tell you what you can do to prevent it from happening again. It is always a good idea to get a professional out annually to inspect your furnace to prevent any problems like this in the future.
