What to Think About When Buying Spackling Compound
Spackling compound is an integral part of any home renovation or refurbishment project. You will use spackling compound for a variety of applications such as filling cracks, patching holes and leveling depressions. There are several types of spackling compound that you can purchase, but it is important to use the right one. Read on to learn what you should consider when buying a spackling compound.
Types of Spackling Compound
There are two types of spackling compound: powder and ready-made. How you are going to use the spackling compound will directly impact which of these types you will use. Powdered spackling compound has to be mixed with water until it reaches the right density. Ready-made compound, if not properly stored, will dry out quickly, while this problem is not present with the powdered stype. Powdered spackling compound will allow you to use as much or as little as you need on demand.
Purpose
The project you are working on will also impact the type of spackling compound you require. If the job is as simple as patching a few small holes, covering nails or minor cracks then ready-made spackling compound in a small tube will be more than enough for the job. If using spackling compound to seal drywall, make complete patches or doing entire walls then a powdered spackling compound will most likely be needed. Also consider if the project is short or long-term.
Drying Time and Reaction
There is a small learning curve when using a spackling compound. To have a stable area to continue repairs, you need to make sure the compound is dry. Drying times differ depending on the brand you purchase. Read the instructions on the container before you buy.
It will be difficult to discern whether some compounds are dry or not. One of the best kinds to buy is the compounds that change color as they dry. Spackling compound will typically go on white but remain white. Other spackling compounds will go on pink but change to white as they dry. This type of compound is perfect for filling large holes and cracks.
Always use the drying time provided by the manufacturer and be certain it fits within your time line. If you decide to rush a job by painting over or treating spackling compound that is not fully dry you will wind up with a crumbling compound.
Cost
Spackle is actually a brand name but is used to describe all fillers used in construction. You will find many kinds of the filler when you go shopping. Some will be the actual brand while others will not be. These filling compounds all work in the same manner but the choices provided create a price war that you can benefit from. Buying in bulk, if warranted, can save you a lot of money. If you are not planning on doing any other jobs using a spackling compound and the job is small then a tube of compound is enough.
