What to Want in an Upholstery Cleaning Product What to Want in an Upholstery Cleaning Product
Homeowners spend hundreds and thousands of dollars on expensive pieces of furniture and as such an upholstery cleaning product is important to maintain them. There are hundreds of products on the market that are sold to clean upholstery. Each of these products can do many things that are important to maintaining the integrity of the upholstery so deciding on the right product for you can become not only expensive but also confusing. The following article will help you understand what you should be looking for in a product to clean your upholstery.
Expensive Does Not Mean Quality
Many people equate cost to quality and that simply is not the case with an upholstery cleaning product just like it is not so for many other products. In many cases a cheaper upholstery cleaning product can do as good a job, if not better, than more expensive ones. These products can cost as little as $5.00 and as much as $15.00, but typically a product priced in the $7.00 to $9.00 range will be the best product for you. Price is dictated by brand as well as chemicals so read the labels thoroughly.
Toxic Chemicals in Upholstery Cleaner Products
If you need to clean your upholstery but do not want a product that can either harm you, your family or the family pet then you have to pay close attention to the ingredients. Many upholstery cleaning products can be compared to the chemicals found in the dry cleaning field. These chemicals may include perchloroethylene which is a carcinogen which affects the central nervous system and naphthalene which is considered toxic if breathed in. Other chemicals that may be present include ethanol, a multitude of detergents and ammonia. There are natural products you can buy, but the price is slightly higher than other products which contain these chemicals.
Multipurpose Cleaner
Upholstery cleaner is not only great for cleaning upholstery but can be used on other fabrics as well such as carpet and denim. The reverse is also true. Many products you purchase to clean carpets can also be used an upholstery cleaning product. Make sure that you read the label before you purchase the product to make sure your specific fiber or fabric is not listed in the "do not use" section of the label's instructions.
Stain Removal Factor
Most, if not all, of the upholstery cleaning products on the market will clean stains from the upholstery. You want to look at if they remove just surface stains or if they remove stains that may make their way down to the foam padding. You will also want to look at the kinds of stains they remove. If you need a sturdier product then look for a product that can get out grass stains, blood stains and wine.
Odor Removal
If a stain is left on the upholstery fabric it can start to give off an odor. Not all products will get rid of these smells while others will just cover them up. Look for a product that attacks odor on the biochemical level.
