What Type of Gears a Lathe Drill Should Use What Type of Gears a Lathe Drill Should Use
A lathe drill has several different gears for you to choose from. It is important for you to know the best type of gears available for you to use so that you can get the most out of the drill. Remember that there are several several things that you will need to keep in mind so that you will not do any damage to the drill or the objects that you are working on.
Spiral Cut Teeth
The gears that have spiral cut teeth are the ones that are used the most. You will find that they are able to give off more power and are also good at spreading loads. This is because they can put the loads between a bunch of the teeth as opposed to when there is only one tooth. What this basically means is that whenever you need a lot of power and have a large load then you will need to be sure that you use a gear that has spiral cut teeth. Not only will they provide more power they will also do it at a velocity that is constant. You will find that they are the best when it comes to getting a larger job done quickly and efficiently.
Spur Gears
Spur gears are used whenever you do not have a very large load. They only have one tooth and are not necessarily able to handle the same large load as the aforementioned gear. These are great when it comes to small loads though. Gears that are made for larger loads are sometimes difficult to manage on smaller loads as they can be too much to handle and be harder to deal with. Make sure that you are aware of the load that you have and that you know how much it is going to be before you pick your gear. You will find that knowing the load that you have beforehand will make picking the gear that much simpler.
Spiral Cut Gears
Whenever you are using a spiral cut gear the teeth will give off power at a much higher velocity that is constant. They are also a lot quieter than the previously mentioned teeth gears. This is another option that you will have to consider whenever you have a larger load that you will need to get the job done quickly on. You will find that while there are several advantages to this type of gear there are also a few disadvantages as well. The end thrust that is produced can easily be offset by the other types of gears that are cut by the opposite hand. You will also need to look for better types of lubricant as the constant sliding action of the teeth are going to cause it to wear down much quicker. However, if you do not use this type of gear very often then you will not have to worry as much about the lubricant as somebody that has plans to use it much more often.
