What's the Best Floor Steam Cleaner? What's the Best Floor Steam Cleaner?
A floor steam cleaner is supposed to be effectual and affordable for cleaning floors in both homes and offices. The steam cleaner uses heated water (around 200 degrees Fahrenheit) to create steam vapor that cleans both carpets and solid floors. The steam cleaner also creates dry steam that contains a lower level of moisture and requires scrubbing and rubbing.
Steam cleaners are much more effective in cleaning floors as compared to vacuum cleaners as the steam can penetrate through the surface much better. Moreover, it does not require the use of chemicals that may harm humans to be used in the cleaning process. Additionally, it does not leave any odor that many cleaners leave, and can be used in almost all areas of the house.
Various different manufacturers produce a range of floor steam cleaners that can be differentiated in terms of budget, size, requirements, portability, cleaning type, and preference. The leader in the floor steam cleaner regime is Shark that has a variety of different types of cleaning machines. Three of Shark’s most popular cleaners are discussed below.
SC505 Euro-Pro Steam Cleaner: This chemical-free cleaning tool can help get rid of tough stains, grease, germs, and dirt from your floors. This portable steam cleaner can be used just anywhere and everywhere as it is portable. The 1600-watt unit weights 11 pounds only and takes 4 minutes to heat the water. Since the body is stainless steel, it can resist corrosion from water. The Euro-Pro Steam Cleaner is easy-to-use and holds up to 80 ounces of water. The unit comes with various attachments that clean different surfaces.
Professional Hard Surface Steam Cleaner: This steam cleaner by Shark sticks to its name ‘professional’. The compact, well-designed cleaner work great with almost all sorts of applications in the house and office and helps get rid of dirt, dust, bacteria, virus, and odors. The cleaner allows one hour of cleaning as it has a huge tank.
Shark Steam Blaster: The unit is great for cleaning all types of surfaces like floors, carpets, windows, tiles, and counter tops. The Blaster helps get rid of grout as well that may be growing on your bathroom and kitchen tiles and sinks. Moreover, all stains on curtains, chair seats, sofas, etc. can be cleaned using this cleaner.
