When and How to Use Concrete Resin
Using concrete resin is much like laying regular concrete. There are many different benefits for using concrete resin versus regular concrete. You need to do some research before deciding on what type of concrete to use.
Below you can explore different reasons why and why not to use concrete resin.
What It Is
Concrete resin is made up of bits of stone and other agents to make it thicker. It can be used in just about anything regular concrete can be used for. This includes walkways, patios, driveways, and other areas as well.
Preference
Of course, whether to use resin concrete or not is up to your preference. What you are using this for will be your first clue in deciding what to use. Concrete resin looks a bit darker than others, and shows few signs of damage when it is used. Resin concrete also maintains its original appearance even over long periods of time. This is because resin concrete contains ingredients that actually protect against damage in all conditions.
Cost
One downfall of resin concrete is the expense. Because of resin concrete's durability, and resistance to all types of weather, it comes at a cost. Depending on how you view cost, this could be a deal breaker. You need to weigh out all the benefits of resin and then look at the cost. If you think you could be replacing your concrete area if you don't use resin concrete, take that into consideration when looking at cost.
Resistant
Resin concrete is resistant to a lot of things including staining. It is resistant because of the ingredients it contains to make up this type of concrete. Many types of weather can damage walkways or patios. However, when you are using resin concrete, the ingredients protect and resist these types of weather. As stated above, resin concrete maintains its appearance, and this is because of the resistance ability it has.
How to Use
Resin concrete is used the same as any other type of regular concrete. Sometimes you will find that using resin concrete will contain a few more steps in mixing and applying, but the procedure is about the same as usual. You obviously will need to follow all the steps you would need to follow in laying regular concrete to ensure that it is done correctly.
Resin concrete has many benefits, but creating a shorter timed project is not one of them. Just make sure to follow all the instructions carefully when you are mixing and laying the resin concrete.
Like stated above, using resin concrete is ultimately a decision based on your preference. There is no absolute right or wrong concrete to use for different projects. Just keep in mind the information above, and take into consideration what kind of project you are working on. Do your research, and you should be on your way to creating a marvelous concrete project.
