When to Use Elevator Bolts When to Use Elevator Bolts
Elevator bolts are basically bolts that have a square neck and a flat head with just a partial thread. There are also elevator bolt washers that will go along with these particular bolts. These bolts are not to be used with just any task that you may have. You will find that it is important that you know what to use these bolts for so that you can get the job done correctly. Using these bolts whenever they are not needed could do damage to the area that you are bolting as well as to the bolts themselves. In order to properly bolt something, always make sure that you know the proper bolts to use beforehand.
Some Uses
You will find that you will be able to use elevator bolts for things such as tap drilling or even clearance holes. There are several different sizes of elevator bolts so make sure that whatever you plan on drilling, screwing or bolting, you have the right size bolt for whenever the task is complete. It is also important that you have the elevator bolt washers to along with these bolts so that you can ensure that they match and will go together. Any other type of washers that you attempt to use will not fit properly because of the specific threading of the bolt.
Thread
You will find that the thread of the bolt will have a lot to do with how exactly you will be using it. Whenever you are looking to bolt something, the most important thing that you should look at besides the size is the actual thread that will need to be on the bolt that you will need to be using. An elevator bolt has a very specific thread that will help you to understand what exactly it is that you should look for whenever you are finding the right bolt for the job.
Material
Just about any elevator bolt that you come across will be made from steel. This is something that will have a lot to do with what you plan on using them on. Remember that steel is very solid and sturdy but is prone to rusting. This is especially true whenever it comes into contact with water often. Water can rust steel in just a matter of days. This means that if you plan on using these bolts outdoors, where they can easily get wet, then you may want to consider another type of bolt made from another material.
Sizes
As previously mentioned, there are several different sizes when it comes to elevator bolts. You will need to make sure that you understand as big or as small as they come. You may be able to find some in specially made sizes, but it will cost you more money and they will be difficult to find. When it comes to the length, you can find these bolts to be as short as ¾ of an inch long to a full 3 inches. The body sizes can be ¼”, 5/16” and 3/8.
Some Uses
Different Threads
Material
Just about any elevator bolt that you come across will be made from steel. This is something that will have a lot to do with what you plan on using them on. Remember that steel is very solid and sturdy, but is prone to rusting. This is especially true whenever it comes into contact with water often. Water can rust steel in just a matter of days. This means that if you plan on using these bolts outdoors, where they can easily get wet, then you may want to consider another type of bolt made from another material.
Sizes Available
As previously mentioned, there are several different sizes when it comes to elevator bolts. You will need to make sure that you understand as big or as small as they come. You may be able to find some in specially made sizes, but it will cost you more money and they will be difficult to find. When it comes to the length, you can find these bolts to be as short as 3/4 of an inch long to a full 3 inches. The body sizes can be 1/4, 5/16 and 3/8 inches.
