Why Modular Homes are Sustainable Why Modular Homes are Sustainable
When people think of modular homes, they often imagine hastily constructed, prefabricated homes lacking both substance and charm. Images of row upon row of unattractive units can sour even the least impressionable. However, purely in terms of definition, modular homes are nothing more than homes that are built elsewhere in sections and then moved to their final location. In this dawning age of sustainable housing, well-built modular homes are becoming one of the choices among homeowners looking for sustainable living. As you will learn, modular homes can be extremely sustainable both in terms of materials used and design.
Sustainable Homes
Sustainable homes are those which provide for the present need without jeopardizing the potential for future generations to do the same. The systems that comprise the homes are designed with sustainability in mind. This means that water, heat, power and lighting, among other things, are accomplished in such a way that both reduces costs to the homeowner and reduces the amount of energy required.
Sustainable Modular Homes
Modular homes can be just as sustainable as traditional housing. In fact, because they are pre-built according to very specific plans, they can be designed to be entirely sustainable, making them a better choice when it comes to sustainable living. Homes built from the ground up to be sustainable include many of the most desirable features in green housing. No longer is modular housing considered a detestable manner of living. With sustainable designs, modular homes are sustainable homes.
Features of Sustainable Modular Homes
Some of the features that sustainable modular homes possess include built-in rainwater collection tanks, grey water systems designed to reuse laundry, kitchen and sink water, roofs carpeted with natural vegetation, ample windows for natural light and energy efficient appliances. Other features include solar panels for hot water or radiant heat. The physical layout and position of the home can also have a positive may be included to absorb and store solar energy for heat. All together, nearly every aspect of some modular housing is designed to be completely sustainable, from the walls to the roof to the internal systems.
Insulation
The vegetation carpeting the roofs of certain modular housing ensures a naturally insulated roof. This is truly a green feature, for the roof is covered with soil, plants and organic matter. This type of roof insulates the home from both excessive heat and cold, and it is 100% sustainable. With walls prefabricated to keep heat in during the winter and out during the summer, along with windows that are double-paned and insulated, the home reduces the amount of energy it requires to keep it comfortable.
Sustainable Energy
Rainwater collection, grey water recycling systems and solar radiant heat and/or hot water heat combine to make modular homes equipped with these features almost entirely self sufficient. Water is collected that falls from the sky and in part used in the home. Energy from the sun heats it up for showers and kitchen use. Much of what is used can be recycled with the grey water system. Heat expenses, too, are reduced thanks to solar radiant heat.
As a whole, modular homes can be designed to be almost 100% sustainable by incorporating an array of systems designed to reduce cost and energy use. Because they are built from scratch, they can sustainable from the start which makes them a good way to live sustainably.
