Will adjusting the clutch pedal help add responsiveness to a warn out clutch? Will adjusting the clutch pedal help add responsiveness to a warn out clutch?
A worn out clutch will require an adjustment of the clutch pedal. Over time a clutch will become less responsive and start to feel worn out. Using the adjustment feature of the clutch is the first step in correcting the unresponsiveness problem. Lift the pedal toward the seat, after making certain that the engine is turned off, the emergency brake is fully engaged, and the car is in neutral. This simple procedure will trigger the adjustment mechanism that is built into the clutch and is often all that is needed to restore the responsiveness of the clutch. This clutch adjustment procedure will raise the height of the clutch pedal to a certain degree, though.
