Will cutting with a wet saw reduce marble tile cracks? Will cutting with a wet saw reduce marble tile cracks?
Cutting marble with a wet saw will reduce the cracks in the marble tile as long as you are gentle and careful with the saw. If you guide the saw along the line that needs cutting, it will cut with very little pressure from you. The more pressure you apply, the more likely the marble is to crack.
As with sawing any material, it is important to take the correct safety precautions. Before you begin, make sure that you are wearing safety goggles to protect your eyes from dust and gloves to protect your hands in the event that the marble does crack while cutting it with a wet saw.
