Why You Should Seal Your Basement Floor Why You Should Seal Your Basement Floor
Sealing a basement floor is absolutely necessary to prevent problems. Moisture will seep through the small pores in the concrete from the ground. If the floor is not sealed, it may cause serious mold problems in the walls and flooring in your home, which can be toxic. It can also cause mildew issues, which can ruin carpet, upholstery, and any other soft surfaces. The moisture will also cause paint to blister or peel if it has been applied to the floor without a sealer. The bacterial growth from moisture problems can also cause respiratory problems for your family and pets.
