Wood Blinds vs Faux Wood Blinds
Faux wood blinds are fast gaining popularity because of their wood-like appearance, durability and affordability. If you are in the market for blinds, you may be wondering about the differences between real wood and the faux version. The following information outlines the major differences between wood blinds and faux wood blinds, so that you can make an informed decision.
Composition
Wood blinds are composed entirely of wood, with a varnish or protective coat on top that gives the blinds a glossy, finished appearance. Faux wood blinds, on the other hand, contain minimal or no wood at all.
Faux blinds are generally of 2 types: one is made entirely of vinyl while the other is made of a mixture of vinyl and wood. The vinyl blinds are entirely artificial, but they provide the look of wood. The vinyl-wood composite blinds are made from a type of alloy that consists of wood and vinyl. These blinds may provide a more authentic look and feel as compared to vinyl blinds.
Cost
Wood blinds are the most expensive on the market. Faux wood blinds are much cheaper. The vinyl-wood composite faux blinds are the more expensive of the faux wood blinds, whereas the vinyl ones are the cheapest. Many people who cannot afford the luxury or real wood opt for faux blinds that are pretty similar in look and feel to the real thing.
Qualities
Authentic wood blinds are sturdy and long-lasting if taken care of properly. Nothing can compete with the warm look and feel of authentic wood blinds. Wood blinds just have a natural look that cannot be completely imitated. These blinds are lightweight and durable at the same time. They require fewer slats or ladder, because of the higher sturdiness of the material. There are many different varieties of wood and finishes you can choose from.
High quality faux wood blinds are considered more durable than authentic wood blinds. This is because they are impervious to moisture and humidity. These blinds are easy to clean and maintain. They do not warp, split or crack like real wood when exposed to rough use, moisture or heat. As a result, they are the material of choice for blinds in kitchens, bathrooms and playrooms. You can buy recycled faux wood blinds, which are the best choice for the environment.
Drawbacks
The drawbacks of authentic wood blinds include the high price. Not many people can afford real wood blinds. Also, these blinds are sensitive to moisture. They can cracks or split when exposed to extremes of temperature or humidity. They can also show signs of swelling and deformity when exposed to moisture. Wood blinds are also not considered an environment-friendly choice any more.
One of the major drawbacks of faux wood blinds is that there are limits to your choice of color and choice. Faux wood blinds have smaller slats and you may not find blinds of the exact size you want. The shades and colors of blinds are also limited, because faux wood cannot be stained unlike the real one.
