Drywall Repair with Access Panel
$20
N/A
N/A
3 tools
Water Main Valve and other holes in drywall can be covered with this method. This method provides a quick solution to cover hole in drywall and allow to subsequently access the hole. 1) Using an utility knife the outside of the hole is cleaned. 2) Using a measuring tape, the dimensions of the hole is measured. 3) A chart provided by RoutCad is used to select an Access Panel number. 4) Based on the measurement the Access Panel Number 4 is selected. 5) The Access Panel bracket is aligned with the diagonal of the hole. 6) It is then inserted in the hole. 7) Finally, it is rotated to completely cover the hole.
TOOLS
Measuring tape Utility Knife Access panel
Step 1
Measure the width and height of the hole.
Step 2
Based on the measurement, use the chart to select cover plate size.
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Proud of a Project?
Inspire others with your work.
