hydronic furnace - s8600 module
Post Your Project
by: mikee1 on 11/22/2015 Views 1448
Budget
$0.00
Tools & Materials
  • None
Summary
FYI... I have a vintage Vaillant ninety-two series boiler with an HW8600 auto igniter control. The gas valve, igniter and burner was only working intermittently at best. Noticed the plastic plug for the auto damper was loose. After closer inspection I realized the contact pins for the plug had worked loose from the soldered connections in the back the circuit board. I re-soldered the connections and now the furnace is working great !
Also had a small leak in the heat exchanger and added some Oatey stop-leak, it seems to be working. Hopefully it will last me the winter. Planning to replace furnace with usa made next year if finances allow.
Project Journal
  • Please Wait...
Category:
Tags:
Flag as inappropriate
You May Also Like
You are about to send warning of this page to an Editor. Continue?
