Simple Open Shelf
$15
N/A
N/A
6 tools
1 Cut or have cut to length the laminated pine shelves. The measures will be 3 times 800 x 200 and 3 times 1200 x 300 mm. Mark the sawing route as seen on the drawing above. 2 Saw the holes using a simple jig saw. 3 Sand all the cut pieces in advance so they are nice and smooth. Double check if everything fits into their places by assembling the shelf. 4 Assemble the screws for the corroborating the shelf to the wall using a drill. 5 If you are painting the shelves, wipe to remove any dust and then apply your choice of paint. If applying a sealer or varnish it's also a good idea to do this before you assemble the shelf unit. 6 Assemble all the pieces together. If you want to make a standing shelf instead of a wall shelf, then just skip.
TOOLS
Paint Drill Brush Jigsaw Sanding paper Laminated pine
Step 1
Proud of a Project?
Inspire others with your work.
